I’m trying to add new blinds to a big window/sliding door area. The mounts that the blinds attach to have to be drilled above the window. I thought the patch that I needed to drill was brick as it had been painted over. I’ve since found that it’s part of the window frame so hard metal, maybe aluminium.
I’ve tried all the things I could find about drilling into metal
- Cobalt drill bit
- slow drill settings
- Cutting fluid
- Used a punch to start
I’m barely making a dent. I’m using a relatively cheap ozito drill but it’s always managed everything before. I don’t know if it’s just because I’m struggling to put enough pressure on it since it’s over my head instead of being able to apply downward pressure. I’m at the point where I’m starting to wonder if I can make liquid nails work somehow which seems like a bad idea so any help appreciated
