Hello, I'm looking at creating an entertainment wall next to the staircase, along with enclosing the stairs for storage. I've attached some pictures for reference on what I want to do.
0. Example
2. Timber going from ceiling to floor. I might not put all the way down and put these into pieces to allow for tv to be attached, along with the entertainment unit being attached to the stud timber
4. Blue line - door frame, Green lines - stud frames. Red line - showing extra timber being added to the stud frame and attached to the side of the staircase. This piece of timber would hold the tv mount. Black lines - tv outline & floating entertainment unit
5. Light pink refers to smooth wood veneer attached to stub frames and then slim (3 x 3cm) timber slats sit in front.
6. Shows the underside of the stairs (black line). Smooth wood veneer would either be 1cm or 1.6cm wide and would need to sit flush with the side of the staircase. Red line would be the timber for the stud wall.
Any advice would be greatly appreciated.
