Steep and sloping gardens can be challenging to utilise. Maintenance can also be difficult, with heavy rain causing soil, mulch and gravel to shift downhill.
Landscaping can create opportunities for layered planting, elevated outdoor entertaining areas and striking garden paths. Bunnings Workshop community members have used steps, retaining walls, decking, garden beds and clever drainage solutions to transform difficult slopes into practical and attractive outdoor spaces.
Every sloping site is different, so carefully investigate drainage, soil conditions, underground services and local council requirements before excavating or changing levels. Retaining walls, stairs and decks may require professional design, engineering and approval.
Get inspiration for your home from the following ideas for transforming a sloping or steep garden, and let us know if you need a hand with your project.
1. Divide the garden into usable tiers
Breaking a steep garden into several smaller levels can create space for planting, entertaining and moving around safely. Workshop member @Spackle48’s tiered makeover for a steep backyard combines stairs, paving, garden beds, decking, fencing and outdoor lighting. Corten steel edging, sandstone, gravel and existing large rocks help connect the different levels and make the garden feel cohesive.
2. Create a dedicated route up the slope
A well-planned set of steps can make a steep front yard safer and easier to navigate. For outdoor steps with pavers and pebbles @SMJGGT used treated Pine sleepers to form the steps before adding pavers , pebbles and solar lights. Crucial drainage was also incorporated into the clay slope using sleeved agricultural pipe and drainage gravel.
3. Let the path follow the landscape
Garden steps do not always need to travel directly up a slope. A sweeping path can feel more integrated with the surrounding landscape and become a feature in its own right. Community member @Foxhunt transformed a bare incline using curved timber garden stairs. Each step was individually measured and sized to form the curve, then filled with river pebbles. Stone walls, new planting and mulch soften the timber structure, while a rustic wire-and-post handrail and period-style gate add character.
4. Add landings to a long staircase
Long, steep runs can be easier to navigate when steps are divided by level landings or changes of direction. After experiencing slips and falls on an unimproved property, @Graeme50 built functional staircases for a sloping property using timber and pavers. The stairs were planned around an air-conditioning unit and an under-house entrance that both required landings. A broad landing further down the backyard staircase allowed the path to change direction and made the long descent more visually interesting.
5. Create level lawn or patio space with a retaining wall
A retaining wall can turn part of a sloping garden into a level area for lawn, planting or outdoor living. Workshop member @RenoMike built a retaining wall with timber sleepers and galvanised posts to prepare a sloping front yard for a future patio and lawn. The project used treated Pine sleepers, galvanised steel posts, crushed rock and agricultural drainage pipe. Stringlines helped establish the finished height and alignment, while drainage behind the wall was planned to reduce water pressure.
6. Build a retaining wall raised garden bed
Instead of building a wall that only holds back soil, consider incorporating a practical planting space. A previously unusable slope along the back fence became a raised garden bed retaining wall by @asharkey. Treated hardwood and retaining-wall posts created a generous bed for ornamental plants. Agricultural pipe, drainage gravel and geofabric were installed behind the wall, and a difficult grassed area was replaced with paving and decorative aggregate.
7. Use a deck to bridge the gradient
An elevated deck can create a level destination without requiring the entire slope to be excavated. Workshop member @jase2 built a low-level Ekodeck with a prefabricated pergola on a raised, sloping section of garden. The viewing deck is reached by four broad, gradual steps that change direction to meet the existing garden stairs. Handrails were added to make access easier, while low-maintenance composite decking and a gazebo created a comfortable place to enjoy the garden.
8. Replace lawn with low-maintenance planting
Lawn on a steep slope can be awkward or unsafe to mow. Mulched garden beds, groundcover plants and defined pathways may provide a more manageable alternative. After testing several possible layouts, @Tara86 completed D.I.Y. landscaping for a sloped front yard featuring timber steps, rocks and mulched planting areas.
9. Turn a grassy bank into a habitat garden
A slope that does not need to provide a level play or entertaining area can become a layered garden for wildlife. Workshop member @T-Gilbert transformed a plain, grassy bank into a front yard garden with plants to attract native bees, butterflies and birds. After the grass was removed, edging blocks were used to define the garden layout and topsoil, drainage gravel and mulch used.
10. Make runoff part of the garden design
Water naturally travels downhill, so drainage should be considered early in any sloping garden makeover. In this rainscaping project with rain garden, buffers and a dry creek bed, @DirtMonkey turned a persistent erosion problem into an attractive feature. Water from a downpipe is directed through a rock-lined dry creek bed towards a rain garden, controlling the route of runoff, slowing water movement and giving plants more opportunity to absorb moisture.
11. Support a pathway with a gabion wall
Gabions can provide structure on a sloping block while introducing the texture and natural appearance of stone. Because the front yard sloped away from the house, @Dave-1 used a gabion wall to support a front pathway. The project created a lower, flatter area while supporting the elevated path above. Reclaimed steel mesh was used to form the cages, and broken concrete and mortar were reused as concealed fill behind the visible stone.
12. Use the slope as a play feature
A steep gradient can become part of the fun rather than simply an obstacle to remove. Community member @mattofnotrades transformed an unusable backyard using tiers. More than 60 tonnes of material was excavated to create three level areas connected by timber steps. Two grassed tiers provide space for children to play, with a slippery dip built directly into the garden slope between them. The upper level includes garden beds and an outdoor kitchen with an open fireplace.
How to plan and complete a garden makeover
Experienced Workshop contributor @Adam_W recommends addressing practical needs such as drainage and access before decorative features. His guide How to plan a garden makeover also explains how dividing a large transformation into smaller zones can make the project easier to manage and budget.
More useful step-by-step guides:
More inspiration for sloping gardens
Starting with a bare, sloping lawn, @WelcomeHome completed comprehensive backyard landscaping with curved beds, upper and lower decks, an arbour, water features and bird-friendly planting.
A steep front yard makeover by @bthederan replaced a difficult-to-mow lawn with timber sleeper steps, granite pavers and new garden beds.
A sloping, open front yard became more private and functional in the front garden transformation with a gate house and fence by @Project_Palmetto.
For more ideas, check out:
