I am installing a u-shaped bessa block frame for a garden bench. I'm using Versasmooth interlocking blocks set on a reinforced concrete foundation, and while the Versasmooth blocks themselves don't require it, will be filling the core with reo bar and concrete.
The seat will be made from either Ekodeck slats or merbau.
The frame will be 620mm high; the seat will be at 450mm. Ideally, I want the seat of the bench to 'float' ie no visible supports.
At this stage I am considering making the bench on an independent (likely timber but possibly aluminium) frame, then affixing the frame to the Bessa blocks using something like anka screws and a chemical joiner.
The bench is 1600 long x 500 deep. Total weight will depend on the materials but is designed as a 2-person seat.
Thoughts? Alternatives?
