Hi Everyone
I have a pre existing 6m x 3m Coloubond shed. It would be about 15 years or more old and I want to improve it by doing the following:
1 - Lining the inside walls and roof with structural pine. Most likely 90mm x 35mm H3 rating.
2 - Installing batts/foam board inside the cavities of the walls/roof to create an insulated shed
3 - Fixing 6mm fibre cement to the studs/roof rafters
4 - Painting the walls
5 - Adding electrical wiring (it is already hardwired to a circuit from the house), but will need more cables for extra light fittings and GPOs
6 - Line the flooring with garage tiles
So far I have removed the existing 4mm Amelulin foam insulation and am re-configuring it to attach directly to the walls/roof (I am leaving a small air pocket between the walls/roof for condensation to 'breath')
My next step will be to add the wooden framework along all the walls and roof. So far I have a pretty good idea on how I want to do that but I have some questions:
1 - The shed base framework for the shed skeleton is quite small (about 20mm off the ground x 20mm from the sheds metal walls) and leaves very little room to attach my wooden studs to. Can I attach some steel/zinc extensions along the floor plates to give the wooden studs something to be supported by? I was thinking of using plastic shims under these studs so they are not in direct contact with the 600mm x 600mm concrete slabs the shed sits on
2 - Where the gable roof meets the shed walls there isn't a lot of shed structure to connect the wall studs to. I would rather not drill the studs directy into the thin metal walls as that would leave more problems for weather making it's way into the shed and probably won't provide the support the wood needs to be strong. Can I just leave the vertical studs loose near the roof gable and attach roof rafters to the internal purlins running length ways along the shed? Will this provide enough support for the vertical wall studs?
3 - My sheds foundation is only made up of 600mm x 600mm concrete slabs. Can I anchor any part of my wooden structure into these slabs without cracking/splitting the concrete? It looks as though the base plate structure is already anchored to these concrete slabs.
4 - The existing door is a double slider on small rails at the top. I want to remove this and replace it with a hinged/sliding door that would be installed to a wooden framework at the door opening. The current opening is about 1400mm wide by 1900mm high. Can I build a wooden framework onto the front of the shed walls that will support a door and doorframe?
I have attached as many photos as I have currenty;, but can add others to help with coming up with a plan for my project.
