Hoping for some assistance, I've been having ongoing issues with standing water returning to dishwasher (have fairly recently moved into house). It has no problem draining the sump, however after regular usage of the sink, water begins to accumulate in the bottom of dishwasher and smell.
On the dishwasher I've ensured the drainage works properly, replaced the non return valve on the dishwasher, isolated the water inlet to check for leakage and installed a high loop on the hose.
For the sink, it drains properly/quickly, I've ran a drain auger through the wall drain and no issues.
I'm thinking it could be the design of the plumbing and the fact that the wall drain outlet is positioned fairly high (higher than the dishwasher drain spigot) that is potentially creating issues and causing backflow into the dishwasher.
Any tips/guidance would be great as I'm trying to avoid a plumber/technician unless absolutely necessary.
Thanks!
