Hi All
Any thoughts on how to repair wearing away on a concrete verandah, see photos.
Any thoughts much appreciated - I have no idea how to remedy it.
Thanks and regards
Hello @Sunshine2468
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your concrete veranda.
If this type of damage is prevalent over the majority of the surface, odds are the surface cover of the slab is wearing out. My first suggestion would be to consult a concrete slab specialist. They would be able to assess if the surface needs to be removed and resurfaced. The next option would be to patch the damaged sections with mortar. If these are damaged spots only and the rest of the concrete surface is sound, the sections that have come off might just be weak spots. I propose looking at using https://www.bunnings.com.au/dingo-10kg-mortar-mix_p0760516 to repair the damaged sections.
Let me call on our experienced members @Dave-1, @Nailbag, @TedBear, @Noyade and @DIY4Knuckleheds for their recommendations.
Good Evening @Sunshine2468
I have not seen concrete develop that type of surface before, maybe in an industrial usage situation but at home no :/
My only suggestion would be to mortar the area tho I am not confidant it would stay in place.
Hi @Sunshine2468
It's a Phosphorus chemical stain of some kind though have no idea of the cause. There are companies that can re-surface concrete in dozens of different finishes that are worth considering as a repair. Just Google "concrete resurface's near me"
Nailbag
Thank you EricL, Dave-1 and Nailbag!
