Is it possible to DIY install a flyscreen onto a double awning window such as this?
What are my options?
Hello @Mitch_1990
My apologies for the late reply. I propose building a lightweight frame using https://www.bunnings.com.au/pillar-22mm-x-2-5m-mill-flyscreen-frame_p0339762 in combination with https://www.bunnings.com.au/rolltrak-11-x-25mm-plastic-flyscreen-corner-stake-4-pack_p3960208 or similar. I then suggest using https://www.bunnings.com.au/cyclone-910mm-x-2m-fibreglass-flyscreen-2m_p0335577 along with https://www.bunnings.com.au/rolltrak-4-5mm-x-6-5m-black-flyscreen-spline_p0196311 . The technique is to build the frame just big enough that it can be put in snugly but can be easily taken out as well. Therefore, every time you need to close or open your windows the screen can be easily removed and put back.
Another option to keep the frame in place is to use a https://www.bunnings.com.au/taskmaster-46mm-black-magnetic-door-catch-3-pack_p0035553 .
Let me call on our experienced members @Dave-1, @Noyade, @TedBear, @JoeAzza, @Nailbag and @DIY4Knuckleheds for their recommendations.
Good Evening @Mitch_1990
I do think it would be possible to make up a frame but the locking mechanism is the problem part. If you switched the locking handle over to Whitco Black Lockable Window Winder then you defenently could make up two of the rectangles needed using the parts @EricL has suggested.
However an easier solution may be mounting the magnetic middle strip door curtains - Pillar 120 x 200cm Black Magnetic Strip Flyscreen Door Curtain at the front of the window opening so it hangs over the whole opening.
