Hi there, trying to dig out an old washing line so the kids can play. Any tips? Is it just a matter of keeping on digging?
Hello @PerkinsC
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your washing line concrete footer.
Thank you for sharing that photo of your washing lines concrete footer. This appears to be a very well-built and supported footing; it is usually just a solid concrete block that holds the post in place. This looks like a brick surround was put in place before the concrete was poured in. I propose hiring a pneumatic concrete breaker to split the two levels of concrete. Your objective is to reach the level of the brick line. I then suggest using a grinder with a metal cutting disc and cutting the laundry post. I recommend using a grinding disc to flatten the post to the level of the bricks.
Because the brick level is well below the soil level, I suggest covering the concrete base with soil in the form of a slight mound
Looking at the photos, it appears that the brick foundation is already moderately lower than the soil surface level. By removing the first two levels of the concrete along with the post it should be possible to cover the remaining base with soil and not have any of the laundry footer stick out.
If you want to get lower, I recommend drilling down the first or second level of bricks and progress from there.
Let me call on our experienced members @Dave-1, @Nailbag, @DIY4Knuckleheds, @TedBear and @Remarka6le for their recommendations.
Please remember to wear personal protection such as gloves, goggles and a mask.
Hi @PerkinsC
I would remove the loose bricks and cut the clothesline at the base and fill the hole with soil.
Though you could use an angle grinder, the safest tool would be to hire/borrow a reciprocating saw fitted with a metal cutting blade. Start with the clothesline folded. Then with a helper to hold the clothesline to support he weight as you make your way through the cut. To prevent the blade from pinching, have them gently push the weight forward in the same direction of the cut to support the weight off the blade. Before completing the cut, you should be able to safely push the clothesline over and complete the cut.
Nailbag
Good Morning @PerkinsC
This is one of the eternal problems I thin of when i use concrete in the yard. What happens when i want to remove said item. @EricL and @Nailbag have both suggested to get down to a point and then cut the clothesline. My easier self says yep as well :) My concrete left in the ground and covered up self says "it will come back to haunt you" lol and yes I have several of those concrete issues being held for "down the track"
I would say as long as its deep enough and in an area you wont be putting up anything that needs footings then chop it off low as you can :)
"Is it just a matter of keeping on digging?" - @PerkinsC
Yes - I believe so. Did you want to keep the clothes line intact? Reposition it somewhere else in the yard?
Do you own a crow bar?
https://www.bunnings.com.au/cyclone-1800-x-25mm-hex-crow-bar_p3360665
Thanks all for your comments. They were very helpful. I have sought outside help as I think this job is outside of my scope and more high powered tools are required. Will definitely use this forum again. V helpful.
