What do I need to hide a single cable connected to an extension cable? It is a standard double grarage where the cable starts from the ceiling in the middle of the garage and connects to the power point on the left wall close to the corner
Hi @raffi
I think the obvious choice here would be to use some conduit trunking to conceal the cable along your garage ceiling. In saying this, you may need to use a longer extension lead to give yourself enough slack to run the cable neatly along the ceiling and down to where it needs to connect, rather than having it stretched tightly between the two points.
The benefit of using this type of trunking is that it has a removable cover, so you can simply lay the cable inside and clip the cover back into place without needing to remove the plugs from either end.
You could attach the trunking using screws and a suitable construction adhesive, such as Selleys Liquid Nails Fast Grab.
Given that it's a plasterboard ceiling, I'd recommend fixing it into the ceiling battens or joists where possible. Something like these Zenith 8G x 30mm Button Head Timber Screws would be suitable if the ceiling lining is around 10mm thick and the trunking has a relatively thin base. You may need longer screws depending on the thickness of the materials.
Alternatively, suitable plasterboard anchors could be used to secure the lightweight trunking, provided they're rated for overhead use.
With this being said, if this is intended to be a permanent solution, I would be getting in touch with an electrician and having a powerpoint installed on the ceiling next to the unit. Given that there is a light there, it shouldn't be too difficult for them to install a powerpoint. They could then shorten the cable for your garage door motor and simply plug it in to the powerpoint right next to the motor unit. This would be the cleanest approach in my eyes.
Allow me to tag @Noyade, @Dave-1 and @TedBear to see what they think.
Let me know if you have any questions.
Thanks @JacobZ rather not call an electrician and yep will need to get a longer extension lead. And whats best to hide the cable on the cornice?
Hi @raffi,
Unfortunately, I am not aware of a product that would be great for concealing the cable over the cornice. About the best thing you could do is put a cable wrap over it.
Anything done on the surface will certainly be neater, but it will be visible. Unfortunately, if you wanted things to be fully concealed, then you would need to speak with an electrician so they can route the cable through the wall and ceiling cavity.
All cool thanks
And is there something big enough to also hide the female socket of the extension that connects to the cable?
The best option I could find were these https://www.bunnings.com.au/click-extension-lead-safety-cover-box-dual-pack_p0911849 , which again, is not perfect, but is about the best you could do without involving an electrician.
Good Afternoon @raffi
@JacobZ has described exactly what I would be doing, well apart from the word I would use as in "ducting" instead of "conduit trunking" lol I must admit ive never heard of that term before :)
As to the cornice and cabling, I would not worry about that, I vertical piece of ducting straight up the wall, air gap for the cornice and then straight out to the automatic door controller. I would have the female plug just at the end of the horizontal duct so its supported at that point, the cornice I would just have the cable formed to the same curve. Putting a cover over the female end of an extension cord, mmmmm noooo Im not really keen on that part. You are just providing mechanical protection for the extension cord with a removable duct cover and anything more that that it becomes a permanent install is how I am looking at it.
Looking at your pics I just realised you should go left then up or up and then left, pretty much think of what you have mounted on the wall and running into future shelves :) For the right angles I would finish the duct about 40mm before the right angle and then start the next piece 40mm up, gives a nice curve to the cable.
"Allow me to tag @Noyade,"
Not sure why anymore @JacobZ. I would definitely be going with an electrician, or at least seeking their advice and obtaining a quote. Get them to shorten and re-plug the door motor cord and install a power-point next to it. While they're there, replace that flouro with a LED.
