we have recently just purchased a robot vaccum however we have a 1500 wide x 8mm step to go in our lounge room we are currently renting so trying to keep things minimal and not to costly any idea would be appreciated
Welcome to the Bunnings Workshop community @bcouling1. It's wonderful to have you join us.
We do have a range of rubber ramps and threshold ramps that could potentially help your robot vacuum navigate the step. However, at 80mm high, that's quite a substantial height difference for a robot vacuum to negotiate.
You'd need a relatively long ramp to create a gradual enough incline for the vacuum to climb. Even then, many robot vacuums aren't designed to handle significant inclines, so I'd recommend checking your model's specifications before purchasing anything.
As you're renting, a freestanding ramp would be preferable to anything permanently fixed to the flooring. You could potentially construct one from timber, although at 1500mm wide, it would be a reasonably substantial addition to the room. The benefit to constructing one from timber is that you can make it exactly 80mm high. It would be difficult to find a ramp that is at that exact height.
Does your robot vacuum specify that it is capable of navigating a ramp, and if so, does it give details on the gradient? That would help us determine whether a ramp is a practical solution.
Let me tag @TedBear, @Noyade and @Dave-1 to see if they have any thoughts.
Good Evening @bcouling1
Why does the song "I believe I can fly" come to mind…. :)
My thoughts head the same way @MitchellMc's have. The slope of the ramp will be far too long. 30mm drop over 1m in length would be pushing a robot vacuums ability I suspect (check specs of the model you have) Longer ramps will mean you will be tripping up over it.
You could set up two zones for it to clean at different times of the day, clean the lower one when its less likely to be used (say in the morning) and then when you get home pick it up and place it on the higher level? Depends on how you can program the area and for how long it takes battery wise.
Hi @bcouling1, sometimes the answer to the problem is just not worth the trouble. I have a robot vacuum cleaner. It fills up with dust and needs emptying. We just let it clean one area at a time empty it and move it on manually to the next. In fact, I put up a barrier to prevent it climbing a small step that it likes to go over, but that's just us.
