I have two big shelves that lean back. I know the wall trim has something to do with it but I can't remove it (its my parents' house). Is there any way to make the shelves straight? First image is the bottom of the shelf and second image is the top.
Hello @silver_tear
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your cabinets.
There are two possible options to fix the lean on your cabinet. First is to insert a piece of timber that is the same thickness as the skirting board at the bottom at the top back of your cabinet. This will push the top section of your cabinet forward and it will balance out the cabinets level and eliminate the lean. You can use double sided tape or screws to attach the timber insert at the back. My best suggestion is to measure the thickness of the skirting board so that you'll know what thickness you'll need
The second option is to use an https://www.bunnings.com.au/ozito-pxc-18v-compact-multi-function-tool-kit-pcmfk-200_p0800108 and cut the bottom back of your cabinet. This will create a rebated section that will allow you to push the cabinet all the way to the wall and avoid the skirting board all together. One possible issue with this solution is that the cabinet might not have a lot of clearance at the back and the cabinet drawer body and drawer itself might be in the way. If so, then cutting the back is not an option as it will compromise the cabinet's structure. My best advice is to check the back of the cabinet to make sure you have enough space to cut off and that it will not interfere with the structure of the cabinet.
Let me call on our experienced members @Dave-1, @Nailbag, @Noyade, @TedBear and @JoeAzza for their recommendations.
Hi @silver_tear
The floor to wall isn't square to start with. You could remove the skirting and push the wardrobe closer to the wall to close the gap. But to fully close it at the bottom, you will need to put packers under its bottom rear to square it to the wall in order to push it all the way back. Though doing so will leave a gap along the floor. This could be covered using quad in say Tassie-oak to closely match the floor. Then use a gap filler along the wall where it meets the wardrobe. Then cut the old skirting into a short piece to place into the gap between the wardrobe and door architrave.
Nailbag
Good Evening @silver_tear
Mmmm I have thought about this for years, decades in fact.
Personally Id leave it as is, mainly because the lean (minimal) means its that much less likely to want to roll/fall forward.
If you really want it vertical, I would put some rubber stoppers at the top rear of the bookcase (Or a piece of horizontal timber trim across the top back of the bookcase)
I have added folded cardboard at the bottom front of my bookcases to give them that lean you have :)
Reasons I have thought why is this so -
I still havnt figured out an accurate reason :) I think there is but I am not a carpenter.
