Hello,
How to remove this from wall. Seems very tight and stuck.
Thank you in advance.
Hello @Masum_47
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about the wall outlet for your shower.
Please note that plumbing work needs to be completed by a licensed professional for safety and compliance.
I'm sorry but I am not familiar with this particular wall fitting. It does not appear to be one of those ordinary twists on shower wall fittings. However, any changes that involve moving or reconfiguring pipework (which includes this wall fitting) would be considered regulated plumbing work and would need to be carried out by a licensed plumber.
Let me call on our experienced members @Dave-1, @Nailbag, @Noyade, @TedBear and @DIY4Knuckleheds to see if any of them are familiar with this fitting.
Thank you Eric. Looking forward to
Hi @Masum_47 ,
Those units screw directly onto the threaded water outlet pipe that sticks out a little from the wall. It's tight because it needs to seal the water at the point where it is screwed on. You may be wise to remove the swivel joint to check, but it is likely to just be a ball joint recepticle that doesn't show you anything of what's behind it.
You could use a special type of wrench to wrap around and grip the body, but if you twist it firmly counter clockwise it should come undone. There's likely to also some sealant where the chrome meets the tiles, so that will be adding to the tightness. If so cut through it first using dental floss.
It may be best to get a plumber to remove it using the right equipment, for all the reasons that @EricL has stated.
Thanks @TedBear
There os nothing behind that ball. It's a dead end.
What if i use some allen key on outlet where water comes out and leverage that to twist the whole thing counterclockwise?
I would err on the side of caution and not force the fitting. Any accidental break in the pipework would cause leaking or flooding. I advise leaving this to the professionals as they are prepared to address any damage while they are trying to take off the wall fitting.
Good Afternoon @Masum_47
I am thinking along the lines of @TedBear as well.
If you remove the ball by undoing the thread for the ball, can the cover then be rolled towards you. The water outlet looks like it could be seperate from the cover so maybe there is a sequence to remove
-ball joint
-cover
-then connection will be exposed?
Hi @Masum_47, by Allen Key, do you mean a wrench? There wouldn't be any Allen (hex) Key screw there to undo. You could attach the shower head back on which would give you a bit more leverage,
...but … as EricL has said,
if you damage the fitting by forcing it, you could end up with the bigger expense of having to get a plumber to come and fix up the wall outlet pipe.
You'll need to weigh up the risk, since it is really a plumber's job and they would have the right gear to fix up the pipework should something accidentally break.
I am wondering what you wish to achieve in the end by doing this. Are you fitting a new shower head?
Hi @TedBear , yes trying to fit a new shower head. Thais one is very basic , one hand held.
I removed the ball bearing and there are nothing, like a deadend.
I was thinking it would be an easy remove and fit a new one. I have total of 3 like this and this os first attempt.
Allen key fitting is downward where water comes out (in the picture). I am trying to understand what is attached to wall or the main water outlet.
"I am trying to understand what is attached to wall or the main water outlet."
If Google AI is to be believed - it's a one piece unit…
You're saying you can't remove it cause it's "very tight and stuck."
So what tool/s are you using and how are you using it/them @Masum_47 ?
Allen key fitting is downward where water comes out (in the picture). - @Masum_47
Interesting theory - it does seem a little similar to the key shape. Remove the threaded section and then the cover. Seems a little bizarre though?
But what would I know, I'm not a plumber.
If you cannot mechanically remove this - take @EricL 's advice - and get one.
Hi @Masum_47
The fixture looks like the one shown by @Noyade AI image except the wall side will more likely be female not male. The knurled knob to the ball fixture has nothing to do with how the fixture is attached to the wall. It just tightens/loosens the shower hose.
If the open male connection has a hex keyway for an Allan key or flat blade screwdriver then try to loosen and remove this part. Once out then attempt to remove the outer ring. Though none of your tools will achieve this as they don't open wide enough. But you may be able to pry it around using the large screwdriver in the new side opening as leverage.
Nailbag
