Can I get opinions on these oscillating multi tools as to whether they are good or bad, and which brands to lookat or avoid. Thanks.
Hi @geejaybee,
I trust members of the Workshop community will be able to share their experiences and advice with you. Thanks for making your first post and a very warm welcome to Workshop. I hope you find the site to offer plenty of ideas, information and good fun.
As i am in the middle of a bathroom update, I thought that for grout removal these tools look like the best option. Apart from that there always seems to be a few fiddly jobs were normally tools are a bit to awkward. Thanks.
The Ryobi One system seems to be very popular amongst workshoppers, & if you're already into the One System, buying the “skin” or “bare” version is the way to go, as you already have the charger & batteries.For grout removal, any tool will do the job, but if you later want to do detailed restoration work, then there are quality tools out there, & will pay for themselves in no time.In my case, I started off with a Bosch multitool from their green product line (budget sector), but it soon let me down. I replaced it with a Fein multitool, & like madmickmalone, I'm super impressed with it.I initially purchased a multitool with purpose of removing the chocolate brown wood stain (70s build), so that I could expose & preserve the beautiful wood on our cedar slatted windows.Strangely, the Fein was able sand right to the very edge of the right angle joins, where the cheaper knock off had left a 1-2mm strip of stain untouched.I have no experience of the Ryobi One system, but it would be the smart way to go for your grout removal project. If later on you need to do detailed work, most certainly give the Ryobi a go, but if it falls short of expectations like my Bosch green line multitool did, there are pricier quality units that will be an absolute joy to use.As others have mentioned, quality blades make a huge difference, so don't scrimp.In closing, multitools are brilliant, & a vital addition to any tool collection. They're extremely versatile due to the enormous array of attachments, & are able to get into awkward areas where conventional sanders wouldn't be able to reach.
@geejaybee Definately a handy tool to have in the toolbox. You might not use it all that often but when you do it will be the best tool for the job.
I recently had to remove some skirting boards but could not pry them off due to the height of the carpet. Out came the multitool with a Diablo metal cutting blade and simply cut through all the nails behind the boards and lifted them out.
The current Ryobi One+ version has a detachable head and you can get more heads to fit that will turn it into various other tools such as a jigsaw or impact wrench. It wasn't marketed to do so in Australia but the clips are just hidden under the rubber grip. You can buy the range of AEG heads from Bunnings that will suit it.
I believe that they are bringing out a new version at some point that will no longer have this feature but I am not sure exactly when. The last time I checked they were still selling the original version.
As others have mentioned buy good quality blades. I really like the Diablo ones and they seem to last pretty well. I have not used their grout removal blade though so I cannot comment on it sadly.
Seeing I am a real newbie to all these new fandangled high falutin thingamebobs.
Some one bought me - probably not a real mutifunction tool - but a renovator and it was so scary I bought the Ozito, and played around with that, true the blades didnt last long, but for the fiddly bits it gave me confidence to use the bigger with more weird blades. Had loads of fun and was great for fiddly little bits and pieces.
Needless to say they have gone for a walk and dissappeared, so it looks like I will be looking out for a new set or just let the 'builder' do all the major bits and I will do the dirty side kick work 🙂
Wishing you well
Janina
Great, thanks for letting us know @geejaybee. Glad to see you got plenty of prompt assistance from community members.
I've moved this post to the Interiors board and changed the label to Tools and Equipment so that other Workshop members in future will be able to more easily find the advice.
I use my Ryobi Multi Tool cordless more than I ever thought possible. Brought it as I had gift vouchers to buy a right angle Ryobi Drill at Christmas and had enough to buy a blower and torch, just made an on the spot decision to buy the Multi Tool. I use it more than my original wish gift of the drill.
I really made a bad mistake and used the cutting blade that came with it on a metal bolt wore the teeth out in seconds. My fault but I think in future I will use someone else's blades. And yes I went into Bunnings never thinking about the different sizes in sanding pads and now have to cut the ones I brought down to size as I had opened the packet and if I got the proper sanding pads I would have ended up with twice as many for the same price.
Nice easy to manage light weight and makes difficult corners a breeze.
@John1
quote John1:
"I really made a bad mistake and used the cutting blade that came with it on a metal bolt wore the teeth out in seconds. My fault but I think in future I will use someone else's blades."
No sympathy from me mate, everyone knows that the supplied blades are for display purposes only. Besides, you could've saved money if you'd borrowed someone else's multifunction tool, insisted on it being supplied with a diamond blade, & kept it. ; )
