Hey guys,
has anyone retro fit / outfit their garage with the LED baton style range of lights available? Looking to see if anyone has done anything using the lights they have at local bunnings.
Hi @racecars254,
Welcome to the community. We're really pleased to have you join us and look forward to reading about all of your projects and plans for around the house and garden.
Let me tag a few members who might like to share their thoughts and recommendations about upgrading the lighting in your garage: @Seaton, @ProjectPete, @redracer01, @Brad, @Conair400, @TheSaltyreefer
Thanks,
I've installed some with motion detection. I didn't get from Bunnings though as I found a better deal elsewhere online.
Planning to pop another 1 or 2 in there.
Notice Arlec have a smart version...
I have used the Philips batten style LEDs In a few different areas. There is a 600mm or 1200mm version in cool or warm white. One 1200mm will be bright enough to light up a two car garage with 2400mm ceilings, if you're using it as a workspace often then I would put one at either end of the room so theres no dark side of whatever you're working on. I usually wouldn'T buy LED lights retail because ebay is usually way cheaper, but these Philips battens are unusually well priced. Philips make the best quality and usually the most efficient LED chips for home and auto products so they are usually too expensive to justify the price, but these battens are only a bit more expensive than cheap ebay ones, so defs worth it for the convenience of not waiting for postage.
The only time I have been dissatisfied with them was for my workbench lighting. The ceiling above it is 3.6m high and the bench is 1550mm x 2450mm. I have 2 x 1200mm battens which light up the whole room but I find they're not bright enough for detailed work. I think i would probably need at least another 2 of them for what I need, but for $120 there are more suitable options, like a hanging ufo style high bay LED.
TL;DR - Unless you have high ceilings and do detailed work, the Philips battens are a great value option for garage lighting.
Welcome to the Workshop community @dmgdesign.
Thanks for jumping straight in on the discussion with some great feedback. You'll find the community is full of very knowledgable members who contribute their projects and assistance here daily, so we're sure you'll fit right in. Please hit the "Start a discussion" button anytime you need assistance or have a project to share around your home or garden.
If you need any help getting the most out of the site or had questions, please let me know.
any part numbers or links to those?
Hi @PeterOZ,
Let me mention @dmgdesign so they are alerted to your question and hopefully can answer it for you.
@PeterOZ @racecars254 The Philips 20w LED Battens are great value in my opinion at $27.50Philips 20W 4ft Diffused IP20 SmartBright Cool Daylight LED Batten
The light output is roughly comparable to a 36w Flourescent batten, or an old 100w incandescent bulb. NB: The battens are hard wired to the lighting circuit (ie:no cord) and require a licenced electrician to install them. Depending on the amount of light and coverage required you may need a few to get decent lighting levels. If it's just general lighting so you can walk around without tripping over things, one might be *just* adequate. If you plan on lighting a workbench, a couple of battens suspended above the bench might be the best solution.
I'm looking for better lighting than those.
Latest research leads me to something like these. Twin 36W LEDS diffused.
https://www.rexel.com.au/are/category/Light-Fittings/Batten/Batten-luminaire/BATTEN-DIFFUSED-EL-2X36W-1200MM-PRISM-SQR-SLIMLINE/DAVLPS236EL/p/11620088?gclid=Cj0KCQjw8rT8BRCbARIsALWiOvQLHrkoqZFthHLqY1YNJiy8D75BVn6UlE7-r940X7AJGEyUaeFWyg0aAtpIEALw_wcB
or . . .
https://haymans.mmem.com.au/sals9733l-2f-215tc
Hi
I did do some batten lighting in the garage about , but products I used are not from the green shed.
Pic taken at night, i think these were the 36 w slim bateen
