Interior - Cracked mortar in cornerHi All,
I'm planning a garage makeover inside with a fresh lick of paints (before a floor epoxy coating and new storage) but before I do that I've noticed these cracks (highlighted in red) in the mortar between the blocks (no cracks in concrete masonry blocks which is a good sign I feel).
I want to fix the mortar before painting so is sealed, especially since I can see daylight through one of the areas and don't want water coming through.
Reading other similar posts, do I caulk with some mortar repair or use some cement mortar mix? Inside and/or outside? I'd appreciate any product suggestions.
It is mainly in one corner of the garage so I am concerned there is water pooling from rain making the clay soil move more moving the slab but the floor has no cracks so I don't think it's a massive issue currently.
I want to give it a go myself so I ideally want to keep it on cheaper side so any reassurances to avoid any full structural repairs is appreciated.
Interior - daylight between blocks
Exterior - visible mortar cracking
Interior - beside column
Exterior - base
Photo - showing daylight from inside.
Close up of mortar.
Do I seal this up with something?
External wall faces neighbours garage wall so doesn't have to be aesthetically pleasing as can't see it.
Interior with cracked mortar near column.
Do I scrape these rocks away and grade with something so rain drains away from slab?
Location is Victoria, Australia.
Appreciate any advice.
Cheers.
