Hi, I have a couple of Makita circular saws that I inherited from my dad. One is fairly large and corded and the other is fairly small and battery operated. Neither are Plunge saws (i.e. need to start at edge).
I'm looking to find the easiest way to cut straight edges without slipping. So far, I've used a temp bit of straight wood, but I don't have low profile clamps, so this has always been a challenge to keep it secure any avoid movement. I'd want something at least 1200mm long.
I've looked at edges like this (https://www.bunnings.com.au/masterfinish-1-8m-straight-edge_p0138935), but I don't think its primary purpose is for circular saw, and I'm concerned it may be too thick and get in the way. I've also looked at a guide rail like this (https://www.bunnings.com.au/makita-1400mm-guide-rail-track-194368-5_p0590493), but I think it's really intended for a Plunge saw to run along the guide rail (although would probably do the job).
I've also looked at this clamp (https://www.bunnings.com.au/makita-2-piece-g-type-clamp-set-for-guide-rails-194385-5_p0673394), but I think I could find something with an even lower profile, and this looks to be specifically made for the guide rails, not any edge.
What do most people use to help with this? I don't need anything fancy I don't think. Just a thin and straight edge, and low profile clamps so I can position to any angle easily.
