Bathroom, laundry, kitchen refresh
RohanH
Junior Contributor
Re: Refresh a bathroom / laundry/ kitchen zone
Love it! Especially the vases, they really bring the bring the place to life! I'll certainly consider the ceramic dolphins.
I'm hoping to have the cooktop front flush with a diagonal benchtop extending between the two benchtop surfaces but this might be may be tricky to model. Hopefully that will leave the drawers unencumbered.
Really appreciate the models!
redracer01
Trusted Contributor
Hello Rohan,
As promised here is your bathroom models.
Things to consider in this configuration:
- Standard washing machine height is 850mm you dont want your vanity too tall otherwise it becomes a pain to reach and use.
- You must have adequate access to the laundry taps. It must be easy enough for you to put the washing machine hoses on and for the machine outlet to be pluged into the plumbing outlet. It looks fantastic but if I have to call a handy man or a plumber to turn the taps off every time there is a leak . . . you may want to consider final position of washing machine taps.
- Plumbing for your vanity sink will be difficult and may need to use special fittings to avoid the washing machine.
- I suggest a sliding cavity door. This will take out the need for a swing area for the door and freeing up space for the toilet.
- I totally agree with closing off the toilet and vanity area to make it as 1 room.
- I kept a part of the wall separating the toilet and the vanity. This wall indicates the minimum space necessary for you to sit in your toilet area and not feel cramped in.
- Best to consult your builder on final position of walls and facilites in that area.
Goodluck and Cheers!
---Best to keep the shelves removable for easy access to plumbing and taps at the back.Best to keep the shelves removable for easy access to plumbing and taps at the back.rt2.pngThis approximately shows you what it might look like once the wall is up and the cavity sliding door is in place.This approximately shows you what it might look like once the wall is up and the cavity sliding door is in place.Nice big space now for you to sit and not get hit by the door.Nice big space now for you to sit and not get hit by the door.Here is the view from outside going in with the sliding door visible.Here is the view from outside going in with the sliding door visible.
This is the view of what that entrance might look from the kitchen.This is the view of what that entrance might look from the kitchen.
cmtbuild
Newbie
Re: Bathroom, laundry, kitchen refresh
Hi Rohan, I hope your end result.hss turned out good. I would like to ask which programs you have used for the floor plans and for the 3D image as we as about to do some renovations and would love to use this to give us some ideas.  Thanks
redracer01
Trusted Contributor
Hello @cmtbuild
I used an old program called sketchup 8. It is what I use to sketch all my ideas.
Thanks for joining in the discussion @cmtbuild. Great to see you get such a prompt reply from the ever-helpful @redracer01.
This must be an exciting time for you with your renovation work approaching. I'm sure the Workshop community would love to help you with ideas, advice and inspiration.
I would encourage you to hit the Start a discussion button and share some photos of your house and some information about your plans. We have loads of experienced members who are happy to share their experience and knowledge.
Welcome to the community,
jowens
Budding Contributor
Awesome like the drawings and how you put things so clear to see. what program did you use to do this.
Hi @jowens,
Thanks for joining in the discussion.
@redracer01 uses Sketchup for his excellent plans he shares with community members on the site.
jowens
Budding Contributor
Thank you Jason, will check it out
No worries @jowens. Let us know how you go. I'm sure @redracer01 can share lots of tips.
Hey @RohanH,
Hope all is well.
How are you going with your renovation work?
It would be fantastic to get an update as this has been a very popular discussion in the past year.
Thanks,
