Hello,
I have a new door frame and door installed. The door frame has only been nailed/screwed to the double brick wall (it's an old house). But when the door is closed or if I close the door and push it against the frame, I can see that the frame moves a bit. I am not sure what is the best adhesive that I can use around the door frame to stop it from moving or minimise the movement. I bought some Sikaflex PRO+ but I am not sure if it's suitable. The gap between the door frame and the wall is small 2 to 5 millimeters.
Thank you
Dimitri
