Besser blocks are strong, versatile, affordable and suitable for a range of projects.
Creative Bunnings Workshop community members have used Besser blocks for furniture, outdoor kitchens, garden beds, privacy screens, water features and even swimming pools. They can be left exposed for an industrial-style look or painted, rendered or clad to suit your style.
Get inspiration for your home from these 10 ways Workshop members have used Besser blocks for their outdoor projects.
1. Build an outdoor bench
The hollow openings in Besser blocks can be used to support lengths of timber, making them ideal for creating an affordable garden bench. Bunnings Workshop member @sandy_d turned an empty corner of the backyard into a relaxing retreat with a Besser block outdoor bench and landscaping. Sandra used 14 Besser blocks to create supports at each end of the bench, with six 100 x 100mm Pine posts inserted through the openings to form the seat and backrest. The project inspired the step-by-step guide How to build a Besser block bench seat.
2. Create built-in seating
Besser blocks can form the solid base of a permanent bench for your outdoor entertaining area. Community member @dhanekom used full and half blocks to construct built-in outdoor seating using Besser bricks. Reinforcing bar was installed through the blocks before the cavities were filled with concrete and the back wall rendered. Lower blocks were painted black to help the seat appear to float, with Spotted Gum decking used for cladding. Check out the Mediterranean-inspired Besser block bench seat by @mmryan for more inspiration.
3. Define a fire pit entertaining area
Low Besser block walls can help define a dedicated fire pit zone while also supporting built-in seating and decorative screening. @sannear created a backyard fire pit with bench seating using a combination of standard Besser blocks and decorative breeze blocks. A floating Spotted Gum seat was added to the structure, while stepping pavers and decorative rocks created a low-maintenance surface around the fire pit.
4. Construct an outdoor kitchen
Besser blocks can provide a strong, weather-resistant base for an outdoor kitchen. Member @ReeceD built a Besser block outdoor kitchen to accommodate a kamado smoker and bar fridge. The bottom course was laid in mortar over damp-proofing to create a level base. Besser blocks formed the main walls, while rendered and painted concrete blocks were used for the benchtop.
5. Form sculptural raised garden beds
Rendered Besser blocks can create substantial raised beds. @Samc1234 transformed a bare driveway and side passage with rendered curved garden beds. Besser blocks formed the straight sections of the garden-bed walls, while plywood formwork was used to pour the curved corners in concrete. The beds were rendered and finished with paint before planting and mulching.
6. A base for a living privacy screen
A long Besser block planter can provide enough soil volume for screening plants while creating a neat boundary. @EGuignard constructed a Besser block raised garden bed with screening bamboo after a neighbouring renovation reduced their backyard privacy. The 10-metre garden bed has drainage and was built on a level concrete base. It was painted in Colorbond Monument to complement the existing fence.
7. Make a garden pond
Besser blocks can be used to build a bespoke garden pond. @Wados used blocks when transforming an outdoor entertaining area with a vertical garden and pond. The pond was built on a reinforced concrete slab, with smaller Besser blocks forming an internal step and standard blocks creating the walls. A three-metre-high vertical garden with a central waterfall forms a dramatic backdrop.
8. Combine a letterbox with a boundary wall
The structural core of a front wall or garden boundary can be easily built with Besser blocks. Workshop member @Jewelleryrescue used blocks to create a glass-brick and marble letterbox and retaining wall project. Full-size blocks formed the long straight wall and letterbox pillars, while thinner blocks were cut into smaller sections to create curved areas. Marble tiles clad the masonry and cap the walls.
9. Create a plant stand
Besser blocks are perfect for a simple outdoor plant stand. After receiving advice from the Bunnings Workshop community about preparing and painting concrete blocks, @EV77 created a modular plant stand. The arrangement can be expanded to provide more display space as a plant collection grows.
10. A concrete-block swimming pool
At the most ambitious end of the scale, reinforced Besser blocks can form the structural walls of a D.I.Y. swimming pool. Workshop member @TOS completed a backyard makeover with a concrete-block pool. Engineering drawings and building approval were obtained before excavation began. The walls were constructed from Besser blocks, core-filled with concrete, rendered, waterproofed and finished with mosaic tiles.
