VJ panelling can be a simple and cost-effective way of adding style and flair to a room.
Bunnings Workshop members have shared many examples of how VJ panelling has added style and character to different parts of their homes.
Below are the top 10 most popular VJ panelling projects by pageviews: VJ panelling feature wall
1. VJ panelling feature wall by @craftyhopper
Leanne covered an eyesore and created an elegant feature wall with VJ panelling.
2. Recessed TV feature wall with EasyVJ panels by @ProjectPete
Experienced Workshop member Pete transformed a plain brick wall in his living room into a stylish feature wall using EasyVJ panels.
3. Kitchen island EasyVJ panelling by @ProjectPete
Pete also used Easycraft EasyVJ 63mm panelling on his kitchen island and painted with British Paints Mossy Road. Kitchen island EasyVJ panelling
4. Bathroom makeover on a strict budget by @craftyhopper
VJ panels were cut to fit close to a bathroom's tile and cornice so the only gaps to fill were pin holes from a nail gun.
5. Nib wall bedhead with VJ panels by @EleventhCoastal
Kirsty shared a nib wall bedhead with VJ panelling and floating shelves.
6. Bedroom picture ledge with VJ panel wall by @TheRenoDad
A VJ feature wall with a Pine ledge that gives the whole bedroom a lift.
7. Laundry, shower and toilet makeover by @Joe3333
Joe installed water-resistant VJ panel boards while renovating his laundry, shower and toilet area. VJ panelling bedroom makeover8. Wall panelling in kids bedroom by @kingj11
Using three 1m wall panels painted in Dulux Paris Green Matte, Workshop member kingj11 created a feature wall and finished it with a Tasmanian Oak trim.9. VJ panelling bedroom makeover by @craftyhopper
VJ panelling painted in the colour Yacht Race and Rubble by Porter's Paints helped create a bright bedroom retreat.10. Coastal bathroom reno with VJ panelling by @tamaraharringd
While giving her bathroom a makeover, Tamara used VJ wall panelling to save money on tiling.
Creating a feature wall is easy with VJ wall panels. Follow the simple steps from the Bunnings team in the guide How to create a VJ feature wall.
You can also use VJ panels to build a barn door. Experienced Bunnings Workshop member Mariana (@lifestylebymari) has shared a step-by-step guide on How to build a barn door with VJ panels.
Bunnings Workshop community members have shared many other terrific projects that you can use as inspiration for your next VJ panelling project, including: Home office update with VJ panelling
For more inspiration for your home, also check out 3 ways to create a feature wall and 5 feature walls with wainscoting.
Last updated: November 2023
Hi All I feel so amazed when I look at the projects of VJ paneling doneI am attaching few images of the area where I am planning to install the VJ panels . Can I please request the experts to guide for the below things1) How to End the VJ Panels . ( Wall 2 : 1760 Wide and 2500 Height ) What to install to flush the VJ panels from top and from sides. Also is it best to make a box around VJ panels using Architrave.2) Wall 1 ( Should I use the Architrave around the door of use the VJ panel as Architrave )3) TV Wall : How to join the VJ panels from the left side of the Wall to the right end of the Door. Is there any corner joints we can use for the VJ panels which cover the joints.4) At last which is the best paint & primer to use on the VJ Panels.out of the below which panels are easy to paint and look nicehttps://www.bunnings.com.au/easycraft-9-x-2700-x-1200mm-easyvj100-primed-general-purpose-wall-lining-mr-mdf-e0_p0440018https://www.bunnings.com.au/easycraft-9-x-3000-x-1200mm-easyregency150-primed-general-purpose-wall-lining-mr-mdf-e0_p0330132Thanks you so much for reading and replying to this post. ( Images are attached for your reference ).
Hi @MrBajaj,
To end the VJ panels neatly at the top and sides, you can install architrave (timber trim) around the panels, particularly where they meet the ceiling and walls. At the top, a ceiling batten or flat architrave should be used to cover the gap between the panels and the ceiling, giving it a clean, seamless finish. On the sides, a side architrave will cover the junction between the panels and the walls, creating a flush, polished look. If you want to add a finishing touch at the bottom, skirting boards can be installed to cover any gaps between the panels and the floor.
When it comes to the area around the door, continue the VJ panels around the door opening and then add an architrave around the door to finish it off.
For corners, you can simply butt the panels up against each other, and to cover the joint, you can use a small timber trim like quad moulding, which will create a neat transition.
As for the panels themselves, both the Easycraft VJ100 and Easycraft Regency150 panels come pre-primed, making them both easy to paint. You can use a quality wall paint such as Dulux Wash & Wear for a durable, long-lasting finish.
Hi @MitchellMcThanks a lot for your reply.
Can you please share the Item number for 1) At the top, a ceiling batten or flat architrave should be used to cover the gap between the panels and the ceiling2) skirting boards can be installed to cover any gaps between the panels and the floor3) https://www.workshop.bunnings.com.au/t5/user/viewprofilepage/user-id/52?lightbox-user-images=61760i1533AAE1A5393EF6 ProjectPete Love your work. ( This is my Favourite )
Regards
S Bajaj
Good Morning @MrBajaj
1 - Plaster Cornice or timber cornice could be used. I actually made up a shape out of two types for my garage. Tho kicked myself when I found a very similar item on the shelves afterwards 🙂 It really comes down to the style you want and what you have in your house or room. Id suggest to keep all the main areas (hallways, lounge/kitchen ) the same and if you want you could do the rooms differently but may end up looking a little odd.
2 - skirting boards can be all sorts and as point one it depends on what you want. Same rulings apply. Keep the main areas the same, smaller rooms could be switched but may look odd. When I redid my flooring in the lounge, hallways and bedroom I choose to go with a larger straight edged rectangle profile as it looked more modern. When considering what profile to use factor in how you will cut and fit what you want.
3 - That is a stylish wall, I havnt done a wall such as @ProjectPete but am considering one like it for my foyer. I cant see any edging or overlays so it looks like he has measured and calculated to have it fit correctly. Please note that not all walls are square or even corners. I have tagged projectPete in case he is around and can offer suggestions on how he did it.
As a side not @Nailbag has also done paneling walls and may be able to offer an idea on how to.
Some great info provided by @Dave-1 there, @MrBajaj. I've linked to the product sections and it would be up to you to choose which of those profiles that you prefer.
Regarding the inspiration project you've linked to they have used a cornice at the top and a small timber moulding at the bottom.
Hi @MrBajaj
This is one of the projects I did that @Dave-1 mentioned. Our ensuite didn't have a door so I took the opportunity to replace the plasterboard wall with VJ when installing the cavity slider.
I took my panels hard to the ceiling by using small packers that you can't see on the bottom as they are concealed by the carpet and underlay. I gave myself a 5mm gap on the right side to allow for the intersecting walls not to be 100% true, then used a flexible gap sealer, which was painted over. It was also the curtain side so that was also going to provide some forgiveness. I installed the sheets right to left so the only visual misalignment is a small section top left of the door frame, which is barely noticeable. Again allowing a few mm forgiveness to fill with sealant. The gaps also allow to work each sheet in to place.
Nailbag
Finished panels
Right side wall
Left side wall
Raised off floor
Hi All Sharing you the images for the project so far. ( The project was completed by me and my friend who is a carpenter )Its not yet finished.
I am thinking to use ( Sellys No More Gaps white to fill the gaps )Any suggestion what to fill in the place where we nailed the panels.Request you to please share the tips for the color to use . As you can see from the images the floor is blackbutt ( Brown ) color laminate flooring.i
Morning @MrBajaj
Nice work! Are you feeling happier now? 🙂 I know I would be. Somehow getting the wall covered even with the finishes still to be done just makes me sleep better 🙂
Coulour mmmm I fully admit I am not the best at choosing colours. I was going to suggest "surf mist" but on my screen it looks way to grey. Id suggest some kind of white, maybe with a tiny bit of colour to take away the starkness of the white. Id also consider what light globes you will be using with teh colour of the wall as it can really change the feel fro a room. (warm light, cool light type deal)
As to the filling of the nail holes, you could use plaster such as Selleys 180g Spakfilla Rapid Gap Filler - 180g
Then once dry, sand it and paint as normal.
Nice work, your new VJ panelling looks great so far.
To fill your nail holes, use Spakfilla as @Dave-1 has mentioned, and No More Gaps to seal along the top edge of your skirting and the edges of your beading on the ceiling and the corners.
In terms of colour, I'd suggest something white or cream-coloured. Head into your local Bunnings store and grab some colour cards from the paint section. You can take them home and place them against the wall and floor to see what suits you.
You could also read through How To Choose An Interior Paint Colour and How To Choose The Right Colours For Your Home for some guidance.
Jacob.
Love the variety of options!
