How to prune a peach tree?
We have a problem with our peach tree which i had to cut a few branches because they were dead
- Labels:
Gardening
Planting and Growing
Re: pruning a peach tree
Hello @Dorin88
Thanks for sharing your question about your peach tree. Since we’re now in the middle of autumn and only about four weeks away from the official start of winter, your peach tree is naturally starting to wind down into dormancy. You’ve done the right thing by removing the dead branches now. To help protect the tree through the colder, wetter months, I recommend sealing the pruning cuts with Steri-Prune 250g Pruning Spray Paint from Bunnings. This will help prevent moisture and fungal infections getting into the fresh wounds.
Because the tree’s growth is slowing right down, it’s best to avoid any strong fertilising at this stage. Instead, you can gently improve the soil by lightly top-dressing around the base with something like Richgro Black Marvel Garden Soil Improver, which adds organic matter without pushing new soft growth that could be damaged by cold.
To protect the roots and maintain soil health over winter, spreading Oreco 26m2 Sweet Garden Sugar Cane Mulch around the base (making sure to keep it a few centimetres away from the trunk) is a really good idea. It will help keep the soil temperature more stable and also suppress weeds.
Since fungal problems like peach leaf curl often start developing during the cooler, wetter months, you could also consider spraying the tree with Yates Liquid Copper Fungicide soon while the tree still has minimal foliage, and again at bud swell in early spring, to give the tree a strong clean start.
I'm worried about cutting off the wrong branches and at wrong angle!
Hello @Dorin88
Late winter is the perfect time to properly prune your peach tree to set it up for a healthy, productive spring. Here’s a friendly guide using Bunnings products you can find easily.
First, wait until late winter, just before the tree starts to bud (around late July to early August depending on your region). You want the worst of the cold weather to have passed so you don’t stress the tree too much. Start by grabbing a sharp, clean pair of Fiskars Bypass Secateurs for smaller branches and Fiskars Telescopic Tree Pruner if you need to reach any higher or thicker limbs. Always disinfect your tools before you start DIGGERS 125ml Isopropyl Alcohol - 125ml is perfect for this to help prevent spreading disease. Please remember to spray your tools with WD-40 400g Specialist Lawn & Garden General Use Lubricant when storing your tools.
When pruning, aim to create an open, vase-like shape with three to five strong main branches coming out from the trunk. This shape improves air circulation and lets sunlight reach into the middle of the tree, which helps with fruit ripening and disease prevention. Remove any weak, crossing, crowded, or inward-growing branches completely.
You should also trim back the ends of the healthy branches by about one-third to encourage strong new growth. Always make your cuts just above a bud that faces outward to guide the new growth away from the centre of the tree.
Subject | Author | Posted | |
March | |||
April | |||
April | |||
April 2023 | |||
November 2021 |
