It is a 15m x 5m backyard where I want to erect a concrete planter made of limestone bricks with walls on all 4 sides. I want a long narrow planter of 15m x 0.5m x 1m. The base is sandy soil (class C), so please suggest how should I construct the footing as it is a DIY. Please also suggest what material should I use for the footing so that it doesn't crack due to expansion and contraction.
Thanks @MitchellMc .
I’ll use stone clad on them so should be okay with concrete blocks. However, do you think the block dimensions are okay? 400x200x100 is what I’m planning to use.
You could use Brighton Masonry 390 x 190 x 90mm Besser Blocks, and then the cladding will bring them close to your original size.
That’s a great suggestion as always @MitchellMc Thanks so much
@MitchellMc @Do I stack the bricks on each other by 390x90 side?
