my pincle pine tree is drying very fast. Any solution to stop it from dying ? Please advise me how to take care of it.
Hi @rishad,
You might like to start by reading through How to diagnose a sick plant. This should give you some good general information on common ailments in plants.
As your pencil pine is drying, it seems logical that the issue is related to water. The main things to look at are the watering schedule and the soil conditions.
Are you watering them regularly? If so, what is your current watering schedule? Can we get some photos of the soil? Does it drain quickly or retain moisture for long periods of time?
Ideally, they will be watered deeply 1-2 times a week depending on the soil conditions. Before watering, check the soil to see how much moisture is present. This can be done by sticking your finger into the first 5-10cm of soil beneath your tree. If it is still damp, wait a day or two, if it is dry then water it deeply.
If the soil is in poor condition, this can affect its ability to retain moisture and thus deprive the tree of water. Mixing compost into the soil around the base of the tree can help with water retention and give your tree the nutrients that it needs to thrive.
Additionally, you can add a plant tonic, such as Seasol to give your tree a boost of nutrients to help it get through this rough patch.
Allow me to tag @mich1972 and @Noelle to see if they have any other advice they can add.
Hi @rishad
In addition to the excellent advice Jacob has already given you, I would remove those concrete pavers from the the garden bed. The area of soil able to absorb water and air is very small given the size of the trees. and their roots will likely extend well under the paving stones and the decking. Coveing an area of their root zone deprives them of sufficient moisture and oxygen in the soil to keep them healthy and growing well.
