How to hang Christmas decorations without drilling into brick?
Johno1990
Hi I have Christmas decorations that I’ll be hanging up on my house but I don’t want to drill into my brick wall is there anything I can use that will work
thank you
Re: Christmas decorations
Hi @Johno1990,
There are plenty of options in the Command Hooks & Hanging Strips range that you could use for this. These Command Outdoor Light Clips look like a good option for string lights. Check out Hang Christmas Decorations Using Command Adhesive Hooks for some guidance.
If your bricks are quite rough or uneven, there are also Arlec Brick Clips, which grip onto the edges of the bricks instead of relying on adhesives. Both options are easy to remove once the holidays are over and won’t cause any damage to your walls
If you want to hang things from gutters, there are also these Arlec Entertainment Light Gutter Clips.
