How to install garden hose holder on brick?
KSB
Cultivating a Following
Hi we have brick on the outside of our home and I’m wanting to install a garden hose holder hook. Just wondering if the brick will be strong enough to take the weight off the hose next to the tap. PFA a photo for reference.
cheers,
 Karan
Re: Garden Hose holder hook
Hello @KSB
If the brick wall is made of solid bricks and not ones with holes in them, I suggest using Dynabolts. I suggest bringing the hose holder hook with you so that you can test for size. I recommend not getting anything shorter than 50mm.
However, if the bricks have holes in them, I suggest using the following set below:
Here is a handy guide on how to install the Ramset Chemset anchoring system: Ramset™ UltraFix PLUS Polyester Anchoring Kit
KSB
Many thanx ERIC will work on it as advised
Hello @KSB
Please keep us updated with your progress, we look forward to seeing your garden hose holder installed and ready for use.
