How do I repair rotting decking beside my pool?
Terrysim
My wooden deck is rotting and slats are breaking through where people walk. I want a cheep, easy fix to make it safe and look OK without the expense of replacing all the decking boards.
Re: How do I (CHEAPLY) repair rotting decking beside my pool
Hello @Terrysim
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thank you for sharing your question about repairing your deck panels.
One form of short-term repair is to inspect each decking panel and find out which have been compromised. I suggest using a screwdriver and poking the surface of the decking panels and see which ones need replacing. Once you've identified which panels need replacing, I suggest using 90 x 22mm Decking H3 Treated Pine - 2.4m or similar.
Your goal is to replace only the very critically compromised panels and those panels that are still in good condition can stay. In order to give your deck a nice fresh look I suggest giving it a fresh coat of paint. Please note that this is a temporary fix and eventually the other decking panels will eventually fail and need replacing.
Re: How do I repair rotting decking beside my pool?
Hi @Terrysim,
I hope you found my colleague @EricL reply helpful.
I just wanted to check on the height of the deck and whether it is elevated above ground. Any compromised decking boards on a raised deck pose a huge safety risk and should be attended to appropriately, including replacing the compromised boards. If this is an elevated deck, I propose isolating the area so no one can walk on the boards until you have resolved the issue. I'd also recommend having a professional assess the structure of the deck as often, by the time decking boards break, the deck's substructure is also decayed.
If this is a low-level deck, there is less concern, and I'd suggest you check out this helpful guide: How to renovate a timber deck. Replacing decking boards can be relatively budget-friendly, depending on the number that needs to be replaced. You might like to look at options like treated Pine decking if cost is of concern.
