How to connect the PVC joins for my down pipes?
cash888
Im installing new down pipes to my house for a rain water tank and im having issues getting the connection on.
The down pipe im connecting to a 45 degree into the ground then to the pipe under ground but im having issues being able to push the pipe into the 45 and then into the T join. Im sure there must be a simple knack to do it
Re: How to connect the PVC joins for my down pipes?
Hello @cash888
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your PVC pipe.
Just a friendly reminder that any plumbing works must be carried out by a licensed plumber for safety and compliance.
Would it be possible for you to post a few photos of the joins you are trying to accomplish. Generally speaking, if the joins have the proper ends to them then they should slot in without too much effort, but if they are in reverse then it would be impossible to join them together. Once we see the parts that you have, we'll be able to offer recommendations on how to proceed.
cash888
Hello @cash888
From your photo it appears that the pipe has been installed onto the 45degree elbow. However, if it hasn't, then I suggest changing your elbow to a combination of 22 and 15degree elbows to make a shallow turn that will allow the pipe work to line up. You might need to do a couple of combinations to get the correct turn, I suggest getting an extra set of 22 and 15's so that you can do several combinations. You'll know that you have the correct combination when the pipework slides in neatly and does not pop out or sits incorrectly.
I'm sorry but I can't see the T section you are referring to. is it in another picture?
