How to fix PCV pipe damaged by mower?
Pnk86
I accidentally mowed over this pipe and broke it. What is the best way to fix it?
Re: Mowed over this PVC pipe.
Hi @Pnk86,
You'll have to dig up the pipe, so you have full access to it on all sides for around 150mm on each side of the hole.
You can then use a hacksaw or a reciprocating saw to cut the pipe square on either side of the hole.
Once the pipe has been cut, you can use a Deks PVC Stormwater Coupling in the correct diameter for your pipe to rejoin the two parts.
