How to repair a concrete path?
munish77
Re: How to repair a concrete path?
Hello @munish77
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your concrete floor.
I propose cleaning the surface of your concrete path with a pressure washer to remove all the dirt and debris on it. If you are after a light general repair to make it look good, I suggest using Lanko 20kg 173 Floor Leveller on the low and rough sections of your path and Dingo 10kg Mortar Mix on cracks and deeper damage on the floor. Once the path's surface is repaired, I suggest painting it with Dulux 4L Concrete & Paving Super Grip Medium Tint. Please make sure to use the Dulux 4L Concrete & Paving Bare Concrete Etch & Clean and Dulux Concrete And Paving Bare Concrete Primer before using the topcoat.
