How do I clean this white sink drain cover? This is how it looks after using exit mould and scrubbing. It's like the mould is embedded in the plastic.
Is there anything else that could get rid of it or is easy to replace with a new one?
Thanks in advance for any advice.
Hello @Emma04
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your basin waste.
It appears to be a smudge or stain on the plastic body. I suggest using De-Solv-it 125ml Sticky Spot and Stain Remover and see if the stain remover can melt the residue that has stuck itself to the plastic. My only other suggestion is to use Mr Clean Eraser Pad Block, please make sure that the block is wet before using it on your basin waste.
