A fantastic screening solution using decking timber and terracotta pots.
After building the structure and placing the decking timber in position, I started installing rope to hang the terracotta pots for this vertical garden. By creating two holes side by side on the boards for each pot, I was able to put rope through the first hole, knot the end and track it around the lip of the terracotta pot. I ran the rope through the second hole and knotted it at the back.
I recommend installing irrigation and putting it on a timer for those who are time poor. The irrigation lines can be hidden, poking out between the boards and discreetly watering the pots from the back.
You can also paint the pots to add a pop of colour. Have fun with it.
A vertical garden can provide greenery and colour to enliven a drab location and provide plenty of growing space in even very small areas. Create your own by following this step-by-step guide: How to build a vertical garden.
Workshop member JP_Finlay created this gorgeous vertical garden using old pots and a broken gate.
Darren turned a plain brick wall into an attractive feature with five rows of terracotta pots ready for planting.
Vertical gardens can be beautiful screening solutions for a plain wall or fence. Check out our Top 10 most popular screening projects for more clever screening ideas.
