thanks for the advice.. ive sprayed vinegar around to deter animals none have been intruding since then
and had been using seasol liquid fertiliser.. but will try what youve suggested... the ground looks dry on top but is moist under.. we also have decided to place a pvc pipe into ground to water down to roots ..
as for soapy water ... do you suggest ? dishwashing soap ?
thanks Mich can you recommend "soill improver"?
I suggest having a look at the Yates 17.5kg Dynamic Lifter Organic Plant Fertiliser and Soil Improver. This is used to gently feed all types of garden and potted plants, including Australian native plants. It releases nutrients slowly, improving the structure and moisture retention of the soil as well as encouraging earthworms and beneficial soil micro-organisms.
