How to stop pests eating okra leaves?
suni
Cultivating a Following
Hi ,
my okra plants leaves getting holes seems bugs eating leaves , what to do in case if any one knows would be great help, since its started flowering n fruits leaves getting holes , i water them on alternate days and once a month fertilizer , looking for replies to get more info about this
Re: okra plants leaves
Hello @suni
Your okra plants are otherwise looking healthy and productive, so the holes in the leaves are most likely caused by common chewing pests rather than a disease. From the pattern of damage in your photos, the most likely culprits are caterpillars, flea beetles, or small grasshoppers, all of which are very active once plants start flowering and setting fruit. These pests tend to feed more aggressively in warm weather and usually target softer, newer leaves first.
The first thing I recommend is checking the plants early in the morning or just before sunset, as this is when caterpillars and beetles are easiest to spot. Look under the leaves and along the stems, as caterpillars often hide during the day. If you see any, hand removal is very effective and avoids stressing the plant during flowering.
For treatment, a gentle but effective option available at Bunnings is OCP 40g Eco-Caterpillar-Killer. This is ideal for okra because it targets caterpillars specifically without harming bees or beneficial insects, which is especially important now that your plants are flowering. Apply it in the late afternoon so it stays on the leaves longer and repeat as directed after rain or heavy watering.
If the damage continues or you suspect beetles as well, Yates Nature’s Way Vegie & Herb Spray (special order) is another good choice. It helps control a broader range of pests while still being suitable for edible plants. Make sure to spray both the tops and undersides of the leaves, as insects often feed and hide underneath.
Watering and feeding sound mostly fine, but during flowering and fruiting, okra prefers consistent moisture rather than soil that dries out too much between waterings. Deep watering every two to three days, combined with a layer of mulch such as sugar cane mulch from Bunnings, will reduce plant stress and help the leaves recover more quickly from pest damage. Monthly feeding is adequate, and switching to a liquid fertiliser designed for fruiting plants, such as PowerFeed All Purpose Liquid Fertiliser, at a light rate can help support ongoing pod production without forcing excessive leaf growth.
Please remember to wear personal protection such as gloves, goggles and a mask.
