How to treat Papaya with yellowing leaves?
Wallis00
Hello,
I have a papaya tree that is showing some problems. The leaves are turning yellow one by one, and then they dry up and fall. There is no white powder on the leaves, but as shown in the attached photo, there are white patches only on the stem.
Does anyone have an idea what this could be, and how I can treat or cure it?
Any advice would be greatly appreciated.
Thank you very much!
Best regards,
Re: Help Identifying Papaya Problem
Hello @Wallis00
Thank you for sharing your question about your papaya tree. Your papaya does look a bit stressed. The white patches on the stem likely suggest either a sap-sucking pest such as mealybugs or scale insects that leave behind waxy or crusty deposits or possibly a fungal issue, though the localized nature of the patches leans more toward an insect infestation. The way your leaves are yellowing, drying, and falling off further suggests the plant is under sap-sucking pressure, which impairs its ability to maintain healthy growth and moisture levels.
A great product you can use is OCP 500 ml Eco‑Oil Concentrate, which is a 100 percent plant-oil‑based insecticide and miticide safe for edibles and ornamentals. It effectively targets sap‑sucking pests such as mealybugs and scale, and it even attracts beneficial predatory insects like lady beetles. Since it's organic and leaves no withholding period, you can spray and harvest on the same day ideal for your papaya.
Another good option is Yates 750 ml Ready‑To‑Use Scale Gun Insect Pest Killer, which combines pyrethrum and white oil for broader pest control, targeting scale, mealybugs, whitefly, mites, and more. It's a ready-to-use spray that doesn’t require any mixing, which is handy for quick application.
If you're leaning more toward a gentle, soap-based method, OCP 750ml Ready to Use Eco-Insect Killer is an effective alternative. This soap-based spray controls mites, aphids, mealybugs, whitefly, and other sap-sucking pests, and has no withholding period. It's also approved for use in organic gardens and gentle on beneficials like ladybugs.
To treat your papaya, gently wipe away as much of the visible white deposits as possible using a soft cloth and soapy water. Then spray your chosen treatment thoroughly make sure to cover the stem, leaf bases, and especially the undersides of any leaves, where pests often hide. Repeating the application weekly is usually necessary until the infestation clears up.
For added protection if fungal issues might be present, you could apply a copper-based fungicide across the entire tree (leaves, stems, trunk) to act as a protective physical barrier. One community suggestion is to use a spray such as Yates Copper Fungicide (often available in store) mixed in a garden sprayer and applied evenly.
Please remember to wear personal protection such as gloves, goggles and a mask when spraying your plants.
Hi, Thanks for your advised, i been start using the OCP 500 ml Eco‑Oil Concentrate from few days ago, but it having few more leaves dying, would you please advise if i should replace the soil as well? Or, i just have to wait couple more days? Thank you so much.
Hi @Wallis00,
From the photos, it looks like your papaya is in a relatively small pot, which can make it tricky to maintain the right moisture levels. In a confined space, the roots can’t spread out to regulate themselves properly, and the soil can quickly swing from too dry to too wet. The soil in your images also appears quite dry, which can cause the leaves to yellow and eventually drop. On the other hand, if the roots stay constantly wet, the leaves will also turn yellow and brown due to root stress. Papayas prefer consistent moisture but not waterlogging—they like the soil to be kept evenly damp, especially during warm weather.
I’d recommend either upsizing the pot to something much larger to give the roots more room or, ideally, planting it in the ground where it can establish properly. Papayas grow best when they have space for a strong root system, and you’re unlikely to get a good crop from one kept in a small pot long-term. Addressing the restricted root space and maintaining balanced watering should help improve the plant’s overall health.
