I bought a black plastic raised garden bed from Bunnings
It has no drain holes in the base
The legs are hollow and has a hole in the bottom of each leg
When I fill it with soil the soil will go into the hollow legs
Is this suppose to happen
Hi @Coop4459_hc,
I'm assuming you have a garden bed like this Fountain Products 697 x 425 x 655mm Charcoal Raised Garden Bed. Is that correct?
There is no issue with soil going into the legs.
Excess water will still drain through the soil and find its way to the drainage holes at the base of the legs, whether there is soil in them or not.
In filling the garden bed, you will likely find that the soil falls into them no matter what you do, so it is probably best to just fill them first.
