what can I use to finish this panelling off on the end of this wall as I’m not panelling around the corner it’s just that wall? Thanks so much in advance
You’ve got a few good options for finishing that edge @Jersey1975. One approach is to cut the groove off the end of the VJ panel so it sits neatly against the wall, sand it smooth, and then use filler or caulk to blend it into the adjacent wall for a seamless look. If the wall isn’t perfectly straight, a simpler and tidier solution is to use a small aluminium angle trim over the edge of the panel. This will cover the panel end and create a neat transition to the next wall without needing to fuss with fillers or perfect alignment. It can be held in place with Liquid Nails.
