replacement spindle
althauscam
Community Newcomer
replacement spindle
 hi all, im having a hard time trying to find the same spindle for a kitchen sink refurbishment if anyone could help, as these have stripped
DIYGnome
Becoming a Leader
Re: replacement spindle
Hello @althauscam welcome to the Workshop Community 👋
A complete replacement spindle & housing unit is required as the housing will most likely also have wear on it's inner threads, the closest I could find in a quick search is linked below but I would highly recommend taking the complete assembly to your nearest hardware store to match up sizing, I work a lot with older plumbing fixtures and sometimes close enough is the best you can achieve (in terms of shaft travel), where housings were still usable I was able to swap in a new spindle, hope that helps somewhat.
https://www.bunnings.com.au/shaw-mason-brass-wall-spindle_p0604708
althauscam
Community Newcomer
Thank you for your reply, I do currently have one of those i have tried swapping out but it doesnt sit deap enough as water just gushes out when I turn the tap back on.
Welcome to the Bunnings Workshop community @althauscam. It's brilliant to have you join us, and many thanks for your question about tap spindles.
When replacing tap spindles, it can be best to consider replacing the whole tap set; that way you get matching spindles and handles.
For spindles to be a direct replacement, they need to be exactly the same. As @DIYGnome mentioned, it's best to take your existing spindle to your nearest Bunnings store and speak with a team member in the plumbing section. They should be able to check our stock to see if there is a matching spindle for replacement.
