I found this post and wondering if these products would work on the floorboards in photos
’One of the ways to rejuvenate the shine on your floor is to use Cabot's 1L Floor Polish in combination with Cabot's 1L Floor Clean. This is on the condition that you have a glossy finish on your floorboards.’
Hi @Trudjef,
This method would work well to remove scuff marks and light wear on the surface of the floorboards and then add a light waxy coating from the polish, but it is not going to remove deeper gouges and damage.
There are some areas of damage that I can see in the second image that look a bit more severe that might not be removed using these products.
In saying this, I think it is certainly worth a try as the alternative is sanding everything back and then reapplying a sealer.
