DIY paved firepit area with built-in seating
Codey
Growing in Experience
This is a firepit I made from scratch on a sloping block.
Materials
Render
Cobble stones
Sealer
Concrete
Mortar
Reinforcing mesh/rod
Paint
Sand
Black plastic
Render trim
Treated pine sleepers
Ag pipe
Tools
ozito angle grinder.jpgfloat.pngmallet.pngtrowel.pngwheel burrow.pnggrinder.png
Steps
Step 1
The back yard was incredibly overgrown, so a fair but of clearing was needed before I could start building.
Once cleared, I started cutting into the slope and levelling out the ground. The back of the firepit seat will also act as a retaining wall. I then used a whacker Packer so I could start with a firm surface.
I then dug out the trenches which would be filled with concrete for the footings.
Step 2
Once the bricks were laid I prepared the top slab with reinforcing mesh and the rods were drilled into the brickwork to prevent sinking.
Once the slab was set. I then finished the back rest and started rendering.
Step 3
I didn't want to risk paint dripping on the new pavers, so I decided to paint the rendered brick first, before starting laying the pavers
I placed down black plastic before a layer of paving sand. Then I started laying the cobblestones. The paving is laid on a gentle angle to allow water run off.
After filling the gaps with sand and cement, I sealed the pavers with two coats of sealer.
Step 4
Finally, I inserted the metal fire pit bowl, put down the top soil around the edges, and sprinkled some grass seed to help the lawn grow.
I also added a heap of plants around the outside which should look great when they are established.
Step 5
Dave-1
Community Megastar
Re: DIY paved firepit area with built-in seating
Afternoon @Codey
:laugh: Why do we always end up with projects that have finish dates that are fixed! :smile:
Well done on getting it done in time!
Matkai
Re: DIY Firepit
@Codey
Amazing work, can  you give a bit more information on how you constructed the backrest?  Was this just timber framing?  thank you
Re: DIY Firepit
Hello @Matkai
Let me tag @Codey to make them aware of your question. I suspect that formwork was used to create such a fancy looking backrest, but it's possible that Codey is that talented with a trowel. Let's wait for their confirmation on how they built the back rest.
Codey
Re: DIY Firepit
@Matkai
Hey mate,
Thanks for asking, here's some more images which show more about the backrest construction.
I started by building the back wall in line with the rest of the seat. Then I drilled holes for the reinforcing bar for added support.
To create the sloped part of the backrest, I first started with a run of angle cut bricks, then each subsequent brick was simply laid on top, with the void being filled with concrete. To maintain the correct angle, I created a template out of corflute which could be periodically referenced throughout the process.
The final curve shape was made with an angle grinder, refined through the rendering process.
I hope this helps 👍
Happy building,
Codey
Codey
Re: DIY Firepit
Hey Eric,
Thanks for the prompt. I've just responded to the backrest question from @Matkai.
I hope the images clarify the process.
Codey
Re: DIY Firepit
Hi @Codey
Thanks for that extra information about your back rest construction. It is amazing and very cleverly built!
Matkai
Re: DIY Firepit
Thank you, you are clearly very talented..
Amazing Workd
Codey
Re: DIY Firepit
Happy to help!
TheRenoDad
Having an Impact
This looks unreal Codey! Well done!!
Post may contain sponsored content
Nishan1
Re: DIY Firepit
Now that's how it's done!
Stunning!
When do tickets go on sale?....LOL
Nishan
