Feedback on new solar system
val
New Contributor
Re: Feedback on new solar system
Hi Tony battery back up is the way to go can I suggest a byo system it's a  2.4 battery and it's expand able like the the battery your looking at both can be connect to off peak power so the worst case your be paying the least charges possible any way good luck cheers 🙂
Henno
Experienced Contributor
@stewiesnr the device I use is made by a mob called Solar Analytics who are located here in Sydney and here is a link to their site. https://www.solaranalytics.com/au/.
It's been a boon for me as once you feed in all your relevant stats you can monitor via the web or an app on your phone or tablet.
I've been using it for a couple of years now and it has proved its worth. I just upgraded to a lifetime subscription for $250 which I thought was pretty good value.
Hope this info is helpful to you!
stewiesnr
Budding Contributor
thanks Henno
I have looked at their pages and listened to Johann , looks good, Its the sort of info I am after, to verify when to use appliances and confirm the panels are working and from what they say if there is any concerns their system can advise.
appreciated the information
@stewiesnr@val and @Cornishman,
Many thanks for joining in the discussion. This has certainly been a popular topic and I'm sure will continue to be of interest to many Workshop members.
Let me also extend a very warm welcome to the community. We look forward to reading more about your projects and plans. Please post whenever you need a hand or have something to share.
All the best,
AHoy
Sorry, I still disagree @val. It's fine if you are buying a battery for environmental benefits but for the average person they just aren't worth buying yet. The cost is too high and the recoup is typically a much longer duration than the warranty period, so you might never get your money back. Hopefully battery tech keeps improving and they become worth adding soon.
val
New Contributor
Hi  we are not in disagreement I have a 1.5 kw system which I bought at the begining of the rebate schemes and had a buy back of 68 cents I have not bought a battery for my system as you say the numbers dont add up at present . What I was saying was if you are goinng to buy a expandable battery system look at other brands than the enphase and make sure you connect to off peak to ensure any power you buy from the grid to charge your battery is at the cheepest rate . for me $ 3700 fitted for a 2.4 battery is still to expensive . cheers
PappaGabba
New Contributor
Re: Battery
We have a 10kw/h system that was installed in 2010 under the 61 cent Kw/h payback scheme - it paid for itself very quickly. We are building new highly insulated house as well and was researching battery backup as we live in the NSW Southern Tablelands and  get quite a few power outages (around 2 a month).  I quickly came to the conclusion the current cost of storage batteries was too high and payback period was around 20 years - so bought a 3600 watt generator to maintain base power at the house (fridges, lighting etc).
I figure we are already doing our share of helping reduce climate change with solar panels, All LED lighting, evacuated tube solar hot water, highly efficient water pumps currently being installed in the new house. Also prepaing to plant lots of trees in shelter belts around the farm and intend to 'Supersize" our solar array when the house is finished
Re: Battery
Thanks for joining in the discussion and sharing your experience @PappaGabba. We're pleased you could join the Workshop community and look forward to reading about your projects and plans. Feel free to post anytime you need a hand with anything or have something to share.
Welcome,
AHoy
Re: Battery
@PappaGabba
It's my understanding that even a battery backup won't help you in the event of a power outage unless your system is completely off the grid. Something about protecting the grid?
