Hi I am just looking at ideas for sealing the gap between pool and concrete, there was previously gap sealer applied but was just looking at maybe a better and products to use
Hi @WK71,
If you could upload an image of the gap, it would assist our members in offering some brilliant solutions.
As long as you use a suitable gap sealer for this application, you should expect satisfactory results for many years to come. Of all the gap sealers available, the Sika pool silicone sealant would be the best choice as it has high chlorine resistance and excellent UV and weather resistance. Priming the surfaces to be bonded with Sika 250ml Primer-3N Adhesion Primer will ensure a long-lasting result. Alternatively, the only other method I can think of would be to use mortar, but it will eventually crack with the movement.
I look forward to seeing some images of the affected areas.
Please let me know if you have questions.
Hi Mitchell
Please see attached pics, hope they are ok
Hi @WK71,
Thanks for sharing those images.
Just a quick note to let you know that @MitchellMc will be back on the site on Friday to help. Thanks for your patience in the meantime.
Stevie
Hi @WK71,
I'd suggest you start by removing as much of the deteriorated sealant as possible with a scraper. You'll also need to remove all the leaf debris from the gap. Using Sika 600ml Black Sikaflex Pro+ Polyurethane Sealant and a Sika Professional Sausage Caulking Gun would be the most economical choice as it appears you'll need a substantial amount of sealant to fill that gap. Once the gap is filled, you can smooth the sealant out for an appealing transition.
The Sikaflex Pro+ does not have quite as good chemical resistant qualities as the Sika pool sealant, though it is likely what they used initially and should last many years. Given the fairly rough nature of the gap, I feel the Sikaflex Pro+ will do a better job at filling the area. The reason the initial sealant has failed is that the gap has enlarged significantly over the years. Sikaflex Pro+ is an elastic sealant, but sometimes the need to re-caulk the joint is unavoidable with this amount of movement.
Please let me know if you need further assistance or have questions.
Hi MitchellMc
Would it be beneficial to maybe pack the gap before applying the gap sealant
William Kappu
Hi William (@WK71),
Once you remove the debris, if the depth of the gap is more than 20mm I would suggest packing it out the bottom with Moroday 10mm x 5m White Gap Filler Rod. Don't bring the filler rod too close to the surface as you'd want the top 10mm of depth to be filled with the sealant. This will allow a sufficient surface to bond onto.
Hi Mitch,
What about 50mm-ish gaps and fairly deep ones ?
I am just not sure what sort of materials should I use......Do I use some sand first ? or all cement or concrete ?
Hello @ddel
Is the gap evident around the entire pool area? If the gap between the pool edge and the concrete walkway is more than 50 mm and is quite deep, I suggest engaging the services of a professional to assess it. Large and deep gaps can indicate structural movement, soil erosion, or inadequate expansion joint maintenance. A professional can determine whether it’s simply a case of replacing or filling the joint with the correct flexible sealant, or if there is an underlying structural or drainage problem that needs more substantial repair.
In poolside environments, a wide unsealed gap can also allow water infiltration, which may undermine the walkway or pool wall over time, and even pose a trip hazard. A licensed contractor or pool repair specialist will have the right tools and materials to seal it to withstand chlorine, UV exposure, and movement, while also checking for more serious causes before sealing it up.
Hi Eric,
There WAS a structural movement which we fixed.
The pool has not moved, but the land did a bit over time hence the gap between pool edge and pavers.
So what do pool repair guys usually use to withstand chlorine, UV exposure, and movement ?
Thank you.
