We are thinking of building a gate to close off access down the side of our house. Because we purposely made this area wide we want to make sure that any gate we put in can open up so the whole width can be utilised when required. (Photo is looking down the side of the house towards the street, the gate would be installed close to the front of the house)
The opening is roughly 2.45m and we will also require pedestrian access, so we thought of doing a double gate design with one 750mm wide single gate and the other side a bi-fold gate made up of 2x 750mm gates. Here is a rough sketch of what I have in mind (hinges are only drawn like that for ease of recognising them as hinges). Gate height 1.8m.
We want to use these Gate Kits for this.
as well as the ‘Rapid Fence 50x50 x1.8m flanged fence posts’ which would be secured to the concrete using chemset anchors.
It can get quite gusty down that section (as seen this past week with the crazy wind we had!) and I’ve worked out that if the gate area was a solid (no slats or anything) it would need to withstand Wind Loads of 3.45kN and Dynamic Pressures of 0.798kPa. Now that doesn’t mean much to me (I used an online calculator) and I have no idea how to this wind information affects my design choice. Would bolting the posts to the concrete be sufficient?
Also, Do I need to reinforce the hinges on the bi-fold side? The gate kit says they’re good for gates up to 1500mm which technically the two gates together would be. I have drawn a spring loaded wheel into my design to help support the bifold - is this actually needed?
And last question: I have searched the bunnings website high and low for a ‘thumb gate latch’ hut have found nothing. There are some latches but they say no access from outside - that defeats the purpose of it being a pedestrian gate!
tl;dr
Questions I need answered:
1. will the rapid fence 50x50x1.8m flanged fence posts be fine to support the bi-fold design?
2. will bolting the posts to concrete be ok?
3. Will the gate kit be ok for a bi-fold design?
4. Do I need a spring load wheel for extra support?
5. Does bunnings sell pretty ‘thumb gate latches’?
Cheers!
Hello @nikkinik
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about building a bi-fold gate.
Please allow me to try and answer some of your questions.
Here is a handy step-by-step guide: Peak Gate Kit
Hi @nikkinik
The first thing that comes to mind is the extreme weight of the two right sided bi-fold gates supported off each other to a wooden post even with the support wheel. Overtime, I think over time there will be issues with sagging effecting latching and overall finish.
Appreciating the need to have access to the well planned wide side, but unless you have a specific need to have this type of design, I personally would instead consider 2 gates. One can still be longer (temp fixed) than the main one you would regularly use on a more daily basis. I would consider installing this at the front narrower section.
Regards, Nailbag
Good Evening @nikkinik
Mmmm lets roll through your questions ![]()
A - I dont think so, especailly with the wind you describe.
A - Larger sized posts as @EricL has mentioned, yes
A - Dont know but really like the kit in that video
A - It will definently give a longer life to the gate as it carries the weight and its not all carried by the posts.
A - Another dont know so will go with Erics Answer.
Going through your design I am wondering why you want a bi-fold gate. I like the Engineering side to it but think its going to be a complicated way to do the job. (Not that it cant be done
A short gate on the left hand side (looking towards the rd) and a a gate the same size as the bi-fold on the right. It will be easier to carry the load and more steady as the whole gate would be rigid. Definently with the wheel idea to stop sag of the 1.8m high gate.
Another thing you could do is have a removable steel post in between the two gates. This is what you could "clip" both gates to to secure them and when needed to open the whole width you just pull the post up and out. Think A large pipe/hole in the concrete with the removable pipe being 5mm smaller in width then the hole. This will also support the gate from flapping in the wind as well as securing it from being opened. I am thinking the removable pipe to be at least 50mm width (think give way sign or stop sine width) So something solid and the hole to be 300mm deep at least.
There will be less torque force on a solid gate compared to a bifold and the size of the post against the fence (but not attached to the fence) will be the same size (100mm square)
I think the bifold design would just be nice and compact when it’s open. But yeah, probably over engineered! I have reconsidered the design to be 2 gates - one narrower than the other.
Thank you for the reply. Unfortunately we are unable to sink anything into the ground as it is concreted. So I will have to look at an alternate solution - possibly bolting 2 x 100x100 flanged posts close-ish to each other and doing a diagonal brace from the post that is holding the gate to the outermost post? I would then be sacrificing some of the opening width of the side BUT if the final opening is closer to 1.8m instead of the 2.2m it would have been then that would be OK too. Would that give enough support?
If support correctly @nikkinik yes it would be doable, especially using metal framing over timber for those spans Its a much simpler plan having the 2 gates despite loss of some access width.
Hi @nikkinik,
I'd suggest using a 100x100 timber post like @EricL has suggested alongside Pryda 100mm M10 Heavy Duty Bolt Down Post Anchors attached with galvanised DynaBolts, with M10 x 130mm Hot Dip Galvanised Cup Head Bolts & Nuts to attach the post to the post anchor.
This post could then be tied into the brick wall on the house side and the fence on the outer side for additional lateral support. Please note that any attachment to the house and the fence should be assessed and considered before going ahead as additional forces will be applied to them that was not considered in its original construction. If you are unsure of this, it may be worth contacting a professional for their assessment.
I'd also advise considering the Fortress Gates range for the gate as these steel frames are better suited to gates that span a wider distance. The Diagonal Brace Kit will also be essential if either of the gates is wider than 1m.
You can then attach the guide wheel to the larger of the two gates for additional support.
Hi Dave, So would this one be a better option then? pryda-100mm-m10-bolt-down-w-raised-mount-post-anchor
Thanks so much for everyone’s input and advice!
