How to fix table particle board?
Jills
Hello!
Need some suggestions please from the brains trust for a quick fix to help stop this board from making a mess until we can decide if we can get rid of it or fix it properly later in the year.
Thanks in advance
Re: How to fix table particle board?
Hello @Jills
For a quick repair, I suggest spraying the bottom edge with Earl's 250ml Wood Hardener to restore its strength. I then recommend covering the exposed surface with Turbo 175ml Builders Bog Flexipack using a paint scraper. My best advice is to make sure not to use too much activator so that you have time to mould the bog into shape. You can paint the surface if you wish, but keep in mind that this is a temporary fix and the particle board will eventually give way again.
