Loose nails on balcony joist brackets
GoughWitlof
Community Newcomer
Hello, I'm currently redoing my balcony and while I was pulling up the old decking I've found that the joist brackets are fairly warped and have loose nails. The balcony itself is front supported and the joists still seem to be sitting quite squarely in against the wall. Wondering if just bashing in the loose ones will be fine or if this could indicate bigger problems down the line and I should consider adding some screws or something?
I'm very much an amateur at building so any other advice I may not be considering would be very much appreciated.
Thank you!
AlanM52
Re: Loose nails on balcony joist brackets
Hi @GoughWitlof,
I would replace the nails with Type 17 countersink screws.
Screws have superior grip so you don't need to drive a screw into every bracket hole.
Also check-out this discussion.
Hello @GoughWitlof
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your balcony.
It's great that you've received excellent advice from @AlanM52. Just to add an extra idea to the suggestion made, I propose hammering in the loose nails and adding extra screws to the plate.
Let me call on our experienced members @Nailbag and @Dave-1 for their recommendations.
