PVC Pipes for rainwater: Dismantling and reUsing
bm
Cultivating a Following
Hi, newbie here and newbie to diy :smile:
I am planning to realign this  pvc piping positions  and so wondering if there is a way i can dismantle the existing setup  to be reused.
The question really is : Once you join using pvc pipes by applying the cement onto the couplings, how do you unjoin them?  do they come off easily ?
thanks
BM
Re: PVC Pipes for rainwater: Dismantling and reUsing
Welcome to the Bunnings Workshop community @bm. We're pleased to have you with us and look forward to reading more about all your projects around the house and garden. Please feel free to post anytime you need a hand or have something new to share with other members.
Let me tag some helpful community members who might like to share their thoughts on this plumbing job with you: @Brad, @redracer01, @JDE, @Former Workshop member
I'm sure @MitchellMc would also be happy to assist when he is back onboard on Friday.
Please let me know if you ever need help getting the most from the site, or have any feedback about how we can improve Workshop for you.
Brad
No easy job to take them apart!
Hot air gun might do it and clean up is with acetone or sanding.
If you don't have a heat gun then the cheaper option is to cut the joints and start again.
bm
Thank you @Brad  @Jason
redracer01
Hello @bm
The blue glue used on pvc rain water pipes has been formulated to fuse the two pieces together forming a rigid water tight seal that prevents leaks. You could take them apart some will be easy others won't, depends on how much glue was used. But most often those ends will be ruined and will no longer rejoin the part you originally took them out of. Best advice is from @Brad cut it and use new parts to rejoin the lot. Good luck and stay safe.
Red
