Restoring outdoor table and chairs
GailC
We have cleaned, sanded and used Cabots Deck Clean on our outdoor setting.  Perhaps we went too far with the sanding but having purchased 4 lt. of Aquadeck Merbau we are finding it is not covering the wood as we expected.  The first coat is done but it is looking very patchy and mottled and we are wondering if more coats will cover the problem or do we need another paint/stain product.  We are concerned to do too much more and then be told we need to remove all the Aquadeck.
Re: Restoring outdoor table and chairs
You didn't happen to have any before and after photos of this soda blasting process, did you @r23on? I'd be keen to see your results.
r23on
Amassing an Audience
Hi @MitchellMc
Unfortunately I do not I was told about this process sometime ago and haven’t had the need to do, although while in Darwin I showed the Mens shed how to with their equipment. I have also used it on metal to remove light rust and paint from metal as it does not remove any metal.
As stated there are plenty of tutorials on YouTube
Supercheap have product called soda blasting and a couple of videos if this helps
https://www.supercheapauto.com.au/p/safe-soda-safe-soda-blasting-soda---4.5kg/348346.html
