Using clear sealant on a stencil crete verandah.
Pooch2
No pictures. I used a clear sealant bought at Bunnings. That's not the problem to seal my stencil crete verandah, should not have been a big job but there are sections that are showing whiteish patches. The application was a pain too. I had to hold the roller at an angle to release too much product before hitting flooring. Any suggestions??
Re: Using clear sealant on a stencil crete verandah.
Hi @Pooch2,
It would be extremely difficult to diagnose the issue and recommend a solution without some further information and some photos of the white patches you are referring to. Is that them in the first image? Or is that from before you applied it?
Can you advise which specific sealer you used for your concrete?
Also, what preparation steps did you take prior to application?
Are the white patches cloudy and seem to be in the sealer? Or are they more defined and seem like they are on the concrete?
We'll need to do some further investigation to see what has happened and what can be done.
If you can answer the questions above, that would be a great help.
