G’day, please could you help with below queries, thanks.
Query1: What is the minimum load of this dimmer?
Query 2: Is this dimmer compatible with Philips 7.5w LED? (Two in each room, max 15W load)
Query 3: Does this dimmer fit in Deta S-line quad vertical 4 gang switch?
Hi @Newbie450,
Unfortunately, I’m not able to offer advice around electrical specifications. I’d recommend reaching out to Deta directly or speaking with the electrician who will be installing the dimmer, as they’ll be best placed to advise based on your setup.
What I can confirm is that the Deta 200W Universal Electronic Dimmer Mechanism fits within the Deta S-line vertical quad (4 gang) switch plates.
Thanks Mitchell!
