Grid Connect tips, tricks and help
CSParnell
Amassing an Audience
Hi all,
I thought it may he good to have a feed where we could share any tips and tricks to do with any of the Grid Connect Range being Arlec, Deta, Verve, Orion.
I am learning from trial and error and really just accident so sharing with others and sharing back we may be able to create some good learning information for us all.
Please post below starting with what the trick is as the title then how to do so as the body of information.
Carl
AlanM52
Re: Lemaar smart lock help
Hi @Caleb01,
I don't do Grid Connect so I will redirect you to resident specialist @CSParnell.
Cheers
Caleb01
Re: Deta Grid Connect PIR network dropouts and resolutions
Sorry I never updated this thread. They managed to push out an updated firmware version. I had to give them the MAC address of any which needed it. The new firmware auto restarts the switch when it loses connection to your wifi after a period of time. I only notice it once ever three months or so, the switch turns off for 2 seconds then back on when I’m in the shower.
Now I don’t have to power off my whole house to reset them!!
CSParnell
@AlanM52 @Caleb01
Ok looking into these locks here is what I have found out for you.
Here is a summary of the Lemaar Smart Lock unlock methods, formatted ready for a blog post or review.
5 Ways to Unlock Your Lemaar Smart Lock
If you’ve just installed the Lemaar Rectangle Smart Lock or are looking into buying one, you might be wondering exactly how you get in. It actually offers five different entry methods, giving you plenty of backups if you forget a code or a key.
Here is the breakdown of how to open it:
1. Fingerprint (The Quickest Way)
Located right on the handle (or top panel), the biometric sensor is the fastest entry method. It works just like your phone—press your thumb or finger against the sensor, and the handle engages immediately. You can register multiple prints for different family members.
2. PIN Code (Best for Guests)
The lock features a touchscreen keypad for entering a standard PIN (6+ digits).
 * Pro Tip: It has a "Scramble" feature. If someone is watching you, you can type random numbers before or after your real code (e.g., 123 + REALCODE + 890 + #). As long as your real code is in the sequence, the door will unlock.
3. RFID Key Fob (Easiest for Kids)
The lock comes with small RFID tags (fobs). You simply tap these against the keypad area to unlock the door. This is a great option for kids or elderly family members who might struggle with remembering codes or using the fingerprint scanner.
4. The Grid Connect App (Remote Unlock)
You can unlock the door from your phone, but there is a catch: to save battery, the lock "sleeps" and isn't always listening for commands.
 * How it works: The visitor must press 9 + # on the lock's keypad. This sends a "Request to Unlock" notification to your phone. You simply tap the notification to let them in. It acts more like a silent intercom than a standard remote control.
5. Mechanical Key (The "Fail-Safe")
If the batteries die completely, don't panic. The lock includes a traditional mechanical key barrel (usually hidden at the bottom or under a cap). Always keep a spare key outside the home (e.g., in your car) just in case!
Bonus Feature: Emergency Power
If you lose your mechanical key and the batteries are dead, there is a USB-C port at the bottom of the lock. You can plug in a portable power bank to wake the screen up and enter your PIN code.
Sorry it's a bit text book I have not used these ones, I use wifi internal Tuya locks which are similar but different at the same time.
Re: Arlec grid connect
@BillandSue
Sorry for the late reply,
You are in the right section with the
Active period though I'm not a huge fan of the presets in there I prefer to set my own times of start and end times they seem to work better.
You can set different automations for different times of the day say during the day a short 5 second on with a notification (so you get an alert someone is there), at night with a say 5 min timer or countdown and a notification so you know someone is there.
I have a smart PIR sensor setup that way and it work well.
AlanM52
Tuya is something I do... in conjunction (as you know) with Alexa & SmartLife and other related stuff like eWeLink.
There is a plethora of Alexa compatible devices out there (mind boggling) suitable for anyone's budget.
I did not mention Google Home (compatible with Alexa devices) because the Google TV streamer includes a smart hub.
Here I am last year excited about setting the Google TVS before moving to the lounge room.
That setup is on the computer desk return... my sandpit.
Waiting for Google Home to sniff out all the devices and appear on the shortcut menu.
Device list not as yet setup.
Looks like this... Alexa on Win11 Pro  desktop.
I should mention our house is not actually a smart home because mostly all the devices are outside.
Sorry about all that... by now everyone has left the room.
Cheers
Hi @Caleb01,
Unfortunately, like the others, I have not used this lock and consequently can only base things on the instruction manual, which is essentially what CSparnell has attached.
Most times, the best thing to do if you are struggling with Grid Connect products is to give their team a ring on 1800 826 859 in Australia and 0800 003 329 in New Zealand, so their technical support team can talk you through the process. Due to the complex and wide spanning nature of the system, the team who work with it everyday are the best people to speak with. Their operating hours are Mon - Fri: 8:30am - 5:00pm AEST.
If you have any issues getting in touch, please let us know so we can assist further.
Caleb01
Thanks @CSParnell ,
number 4 was what I was after. I didn’t see these instructions anywhere.
Do you have a link to this information on the Lamaar website
Hello @Caleb01
Let me tag @CSParnell as well to make them aware of your query. I had a look on the website but could not find the link you were after. This is a very long thread and some of the comments could be linked to other discussions.
